Civil 3D Forum
stop block cycle with ctrl key
3 REPLIES 3
rfg018
278 Views, 3 Replies
here is a delima, I'm using Civil 3d 2010, and I insert a block with mult. inserting point, press the CTRL and cycle to the insert location I want, then I osnap to the location on the drawing.
the delima is, I use ctrl-rt-click (default) to get the osnap list and pick the osnap, however it is still in the cycle mode, so I can not get the osnap mode.
How do you stop the cycle.
3 REPLIES 3
dasindog
in reply to: rfg018
I don't know of a way to stop the cycle but, you can type in the shortcut for the osnap (end, nea, cen) instead of using the context menu for snaps.
-Dustin
Civil 3D 2013 64 bit SP1
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
NVIDIA Quadro FX 580
explodetheblock.wordpress.com
rfg018
in reply to: rfg018
True, I do type the osnap command for the for the one use mostly, End, app, near, mid, ins, int
I do not know all the osnap commands such as between two points. Yes I could look it up, but I do not use if offen
and some I just keep hitting the wrong keys, my problem.
Anyway this is what I have been doing.
dasindog
in reply to: rfg018
m2p
I setup shortcut keys on all the F* buttons, I find that to be the quickest for me.
-Dustin
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
Rail Community
