AutoCAD Civil 3D General
New Member
Message 1 of 5 (102 Views)
.stb/.ctb
102 Views, 4 Replies
09-04-2013 09:14 AM
I have a template drawing that when I try to plot it looks for a stb file but the plot style table area of plotting dialog will not let me choose a stb ffile. I have my plot style setting set to use named plot styles and even have the stb file set as the default but it still will not select it or even let me see it when I try to plot. Anyone have any insight?
Message 2 of 5 (94 Views)
Re: .stb/.ctb
09-04-2013 09:39 AM in reply to: mpolinske
I have the opposite.
I look for a ctb.
BUT
I set to use named plot styles in the options box and select acad.stb as default and I can STILL only see ctb files.
WHAT?
I would think I would be able to see the stb files. I can see them when it is time to choose the defailt when in the options dialog boxes.
I am using 2013 64bit and I see this issue too.
Hmmmm.
Message 3 of 5 (90 Views)
Re: .stb/.ctb
09-04-2013 09:49 AM in reply to: john.mckenzie
If I type convertpstyles at the command prompt, I can then see the stb files and choose one.
Does this solve your issue?
Message 4 of 5 (87 Views)
Re: .stb/.ctb
09-04-2013 09:53 AM in reply to: john.mckenzie
after you type convertpstyles at the comand prompt you will get ONLY stb options.
Type convertpstyles again and you will ONLY get CTB options.
Acts as a toggle.
Message 5 of 5 (86 Views)
Re: .stb/.ctb
And it does not seem to matter whether options is set to color dependent or named styles.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
