AutoCAD Civil 3D General
Valued Contributor
jmatte2004
Message 1 of 4 (138 Views)
station offset labels of blocks
138 Views, 3 Replies
04-25-2012 11:04 AM
maybe someone can help me. if anyone has a style or know how to set-up a style what i want to do is label the station and offset of the insertion point of a block by selecting that block and placing the name of the block at the end of the label. as such it would read sta: 14+58.25 - L12.50' P Pole
thank you
jason m.
Product Support
SethHall
Message 2 of 4 (106 Views)
Re: station offset labels of blocks
04-27-2012 08:32 AM in reply to: jmatte2004
The best solution I could come up with off the top of my head is that if that "P Pole" originated from a point, you could create a reference text component of the Station/Offset label that pulls the cogo point name. This could easily accomplish what you are describing, however you need the point to be in that location.
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
Being Civil Facebook
Joe-Bouza
Message 3 of 4 (100 Views)
04-27-2012 09:09 AM in reply to: jmatte2004
Adding the Seth's suggestion: if you do not have the points you can extract the block info to csv then import as a point file, and you'll have it.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Valued Contributor
jmatte2004
Message 4 of 4 (94 Views)
04-27-2012 09:15 AM in reply to: SethHall
that would work seth
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
