Member
SteadyT
Message 1 of 3 (231 Views)
(-) sign pulls up drawing menu
231 Views, 2 Replies
12-02-2010 06:37 AM
Everytime I use keyboard commands that include a - sign, Civil3D always opens up the drawing menu.
For example, if I want to use the layer menu, I typically would put in -la to manage my layers via text commands
However, when I hit - , the drawing menu loads up and I need to escape from it (hitting the escape button 3 times!) before I can continue on my keyboard commands.
Is this a setting that I can turn off somewhere?  Thank you.
Valued Mentor
gccdaemon
Message 2 of 3 (226 Views)
Re: (-) sign pulls up drawing menu
12-02-2010 07:15 AM in reply to: SteadyT
I get the same problem. Normally with keyboard shortcuts you'll be able to modify them in the CUI, but I think this may be tied to default windows functions and may be accessable through registry only. Can someone from autodesk chime in?
Andrew Ingram
Civil 3D x64 2012
Win 7 x64 Ultimate
I7 3820 (3.6ghz quad core with HT)
32gig RAM (Corsair XMS3 4x8g)
Intel x z79 mobo (BOXDX79TO 2011 socket)
Radeon HD 7850 2gb GDDR5
Jeff_M
Message 3 of 3 (221 Views)
12-02-2010 07:30 AM in reply to: gccdaemon
There's a thread in the Acad2011 forums about this, with what appears to be a workaround:
http://forums.autodesk.com/t5/AutoCAD-2011/dash-key-goes-to-menu/m-p/2690027#M2584
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
