I am working on a project where we are installing a 6-8' high sound barrier wall near the right-of-way line of a roadway. I have modeled the wall using both the OOTB vertical retaining wall subassembly as well as a one-off assembly created from a polyline. in both cases, the wall is located correctly and shows up in the section views, but I can't figure out how to show the wall in the profile views short of 'pencil-whipping' it in. Dows anyone have any insights on how best to acomplish this?
~g
Can you extract a feature line from the retaining wall corridor object and then project it into profile.
HTH
AWood
I have a similar problem... thinking I should model electric conduit using an assembly, alignment and profile... but I will need to be able to show it in other profile views as a 'crossing'. Using an assembly is necessary since the pipe network tools do not allow for vertical curves and I don't want to model the conduit with many short pipes.
You need an alignment & profile for top and bottom of wall. Superimpose the top of wall profile into the bottom of wall profile view or vice versa.
John Mayo
I would think that awoods method is best but I have an issue with corridor extracted feature lines losing cuvres in 10 & 11.
John Mayo
