AutoCAD Civil 3D General
Valued Mentor
fcernst
Message 11 of 14 (136 Views)
Re: shoulder slope subassembly
01-23-2013 06:15 AM in reply to: KMercier_C3D
Right, that figure he posted, you may not have seen it, shows the OP's shoulder slope criteria is not a simple direct relationship to lane slope.
Ernst Engineering
Fred Ernst, PE
C3D 2014 SP1
W7x64; i7 8gb; Radeon HD 5700
www.ernstengineering.com
Distinguished Contributor
Message 12 of 14 (135 Views)
01-23-2013 06:16 AM in reply to: KMercier_C3D
thanks for all the input.
no, the shoulder doesn't match the lane slope all the time, only in certain instances where the lane slope is greater than 6%. between -1% and 6% the shoulder stays at 6%. from -1% to -5% the shoulder varies in relation to the lane slope. if the lane slope is -3.2% then the shoulder slope is 3.8%. at -6% and greater it becomes crowned. it is a pita. like i said, i've got a profile for the shoulder but any change in alignment or profile really becomes time consuming.
Dell Studio XPS 9100
Intel Core i7 CPU 930 @ 2.8GHz
12GB Ram
64 bit
C3D 2012 SP3.0
*Expert Elite*
KMercier_C3D
Message 13 of 14 (132 Views)
01-23-2013 06:19 AM in reply to: fcernst
I stand corrected. I had missed the *.png that was posted. Definitely an ideal situation for SAC and really a rather simple one at that. I'd still use Parameter References though and have the shoulder SAC have an input parameter of the lane slope and then the shoulder is calculated and generated from there.
Kati Mercier, P.E.
Co-author of "Mastering AutoCAD Civil 3D 2013"
AutoCAD Civil 3D 2013 Certified Professional and AutoCAD 2013 Certified Professional
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Valued Mentor
fcernst
Message 14 of 14 (126 Views)
01-23-2013 06:25 AM in reply to: KMercier_C3D
Yes, that would work through most of the criteria range, except for those steep lane slopes at the top of the criteria range, where it looks like he has a crowned shoulder that is smoothed with a fillet, which SAC could easily handle.
Ernst Engineering
Fred Ernst, PE
C3D 2014 SP1
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
