Civil 3D Forum
shift click
15 REPLIES 15
Message 1 of 16
MonkeyTrainer
9656 Views, 15 Replies
shift click
a normal day is when i have a group of somethings selected, and when i hold shift and click some of those selected somethings, they will unselect. like, you window a group of objects, but then decide to de-select something.
now, when i have a group of objects select, and shift click, it doesn't de-select the object, my command line reads "1 image(s) found". how do i get the shift-click back to de-selecting something?
15 REPLIES 15
Message 2 of 16
dasindog
in reply to: MonkeyTrainer
I read this recently I will try and look it up for you... I rememeber there is a map setting you can disable to keep this from happening.
-Dustin
Civil 3D 2013 64 bit SP1
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
NVIDIA Quadro FX 580
explodetheblock.wordpress.com
Message 3 of 16
dasindog
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/1-image-s-found/m-p/2831495/highlight/true#M140853
imapoptions
general tab
turn off shift+left click
-Dustin
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
Message 4 of 16
jmayo-EE
Raster Design would do this. If it's intalled go to the Raster Design Options dialog, User Preferences tab and uncheck the box for Shift+Left click image select.
John Mayo
Message 5 of 16
MonkeyTrainer
in reply to: jmayo-EE
i dont currently have that installed. is there a text prompt that pops up on the command line someone could post for me that enables/disables this feature?
Message 6 of 16
For some reason in 2013, the Noun/Verb selection keeps turning itself off.  In the Options, Selection tab, make sure that Noun/Verb Selection is checked.
Todd Rogers
BIM Manager
Blog | Twitter | LinkedIn
Message 7 of 16
my box was checked. i also tried unselecting, hitting ok, then checking it again. it still is saying the above quote.
thanks.
Message 8 of 16
Mine did this the other day and a simple reboot of the program fixed it.
Todd Rogers
BIM Manager
Message 9 of 16
tcorey
From the Command prompt, type MAPIOPTIONS, go to General tab, turn off the option to Shift+Left Click Image Select. Now Shift+Left click will de-select objects.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 10 of 16
troma
in reply to: tcorey
So we Shift+click to deselct objects in a selection set, we Shift+click to select grips of selected objects, and now we can Shift+click to select an image too!  Isn't anyone thinking?  What's wrong with Ctrl+click or Alt+click, if we need more clicking options?
Mark Green
Working on Civil 3D in Canada
Message 11 of 16
MonkeyTrainer
in reply to: tcorey
this fixed it. at first, i was just typing mapoptions, without the i. thank you very much.
Message 12 of 16
tcorey
in reply to: troma
I agree, that would allow you to have both features.
Tim Corey
Redding, CA
Message 13 of 16
i Have a quick question for you: how did you figure out this solution? i mean is easy just to come to the forums to get the answers but i wonder if there is any other guides to find the commands that are not so common.
Message 14 of 16
Thirty-five years of doing training and support for AutoCAD and DCA/Softdesk/Land Desktop/Civil 3D. Every time someone asks me a question, I learn something new. Some of it, I remember.  😉
Tim Corey
Redding, CA
Message 15 of 16
chuckriley13
in reply to: tcorey
Thanks Tim, this fixed it for me.
C3D 2021
Message 16 of 16
trandall
in reply to: tcorey
Thanks Tim!
Rail Community
