AutoCAD Civil 3D General
Distinguished Contributor
MonkeyTrainer
Message 1 of 12 (727 Views)
shift click
727 Views, 11 Replies
11-05-2012 06:16 AM
a normal day is when i have a group of somethings selected, and when i hold shift and click some of those selected somethings, they will unselect. like, you window a group of objects, but then decide to de-select something.
now, when i have a group of objects select, and shift click, it doesn't de-select the object, my command line reads "1 image(s) found". how do i get the shift-click back to de-selecting something?
dasindog
Message 2 of 12 (724 Views)
Re: shift click
11-05-2012 06:24 AM in reply to: MonkeyTrainer
I read this recently I will try and look it up for you... I rememeber there is a map setting you can disable to keep this from happening.
-Dustin
Civil 3D 2013 64 bit SP1
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
NVIDIA Quadro FX 580
explodetheblock.wordpress.com
dasindog
Message 3 of 12 (717 Views)
Re: shift click
11-05-2012 06:37 AM in reply to: MonkeyTrainer
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/1-image-s-found/m-p/2831495/highlight/true#M140853
imapoptions
general tab
turn off shift+left click
-Dustin
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
jmayo
Message 4 of 12 (715 Views)
Re: shift click
11-05-2012 06:38 AM in reply to: MonkeyTrainer
Raster Design would do this. If it's intalled go to the Raster Design Options dialog, User Preferences tab and uncheck the box for Shift+Left click image select.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
MonkeyTrainer
Message 5 of 12 (714 Views)
Re: shift click
11-05-2012 06:45 AM in reply to: jmayo
i dont currently have that installed. is there a text prompt that pops up on the command line someone could post for me that enables/disables this feature?
TRogers
Message 6 of 12 (710 Views)
Re: shift click
11-05-2012 07:01 AM in reply to: MonkeyTrainer
For some reason in 2013, the Noun/Verb selection keeps turning itself off.  In the Options, Selection tab, make sure that Noun/Verb Selection is checked.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
MonkeyTrainer
Message 7 of 12 (699 Views)
Re: shift click
11-05-2012 07:21 AM in reply to: TRogers
my box was checked. i also tried unselecting, hitting ok, then checking it again. it still is saying the above quote.
thanks.
TRogers
Message 8 of 12 (697 Views)
Re: shift click
11-05-2012 07:22 AM in reply to: MonkeyTrainer
Mine did this the other day and a simple reboot of the program fixed it.
*Civil 3DJ*
Todd Rogers
Visit my blog here.
tcorey
Message 9 of 12 (651 Views)
Re: shift click
11-05-2012 04:11 PM in reply to: MonkeyTrainer
From the Command prompt, type MAPIOPTIONS, go to General tab, turn off the option to Shift+Left Click Image Select. Now Shift+Left click will de-select objects.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
troma
Message 10 of 12 (633 Views)
Re: shift click
11-06-2012 06:37 AM in reply to: tcorey
So we Shift+click to deselct objects in a selection set, we Shift+click to select grips of selected objects, and now we can Shift+click to select an image too!  Isn't anyone thinking?  What's wrong with Ctrl+click or Alt+click, if we need more clicking options?
Credit where credit is due! Give kudos or accept as solution whenever you can.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
