a normal day is when i have a group of somethings selected, and when i hold shift and click some of those selected somethings, they will unselect. like, you window a group of objects, but then decide to de-select something.
now, when i have a group of objects select, and shift click, it doesn't de-select the object, my command line reads "1 image(s) found". how do i get the shift-click back to de-selecting something?
Solved by tcorey. Go to Solution.
I read this recently I will try and look it up for you... I rememeber there is a map setting you can disable to keep this from happening.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/1-image-s-found/m-p/2831495/highlight/true#M140853
imapoptions
general tab
turn off shift+left click
Raster Design would do this. If it's intalled go to the Raster Design Options dialog, User Preferences tab and uncheck the box for Shift+Left click image select.
John Mayo
i dont currently have that installed. is there a text prompt that pops up on the command line someone could post for me that enables/disables this feature?
my box was checked. i also tried unselecting, hitting ok, then checking it again. it still is saying the above quote.
thanks.
From the Command prompt, type MAPIOPTIONS, go to General tab, turn off the option to Shift+Left Click Image Select. Now Shift+Left click will de-select objects.
So we Shift+click to deselct objects in a selection set, we Shift+click to select grips of selected objects, and now we can Shift+click to select an image too! Isn't anyone thinking? What's wrong with Ctrl+click or Alt+click, if we need more clicking options?
Mark Green
Working on Civil 3D in Canada
this fixed it. at first, i was just typing mapoptions, without the i. thank you very much.
I agree, that would allow you to have both features.
i Have a quick question for you: how did you figure out this solution? i mean is easy just to come to the forums to get the answers but i wonder if there is any other guides to find the commands that are not so common.
Thirty-five years of doing training and support for AutoCAD and DCA/Softdesk/Land Desktop/Civil 3D. Every time someone asks me a question, I learn something new. Some of it, I remember. 😉
