I'm running AutoCad 2012 Civil 3D and I've imported a shapefile and would like to show the ESRI labels in AutoCad. The shapefile is a maze of pipelines in an oil field and the owners and sizes of the lines are in my GIS table.
If you chose to Create Object Data when importing the .shp file, you can use the Map Task Pane (MAPWSPACE) to add a text stylization based on the object data.
HTH
AWood
