Finally jumped on the 64-bit wagon and was installing service packs and configuring C3D 2010 and C3D 2011. Our IT guy had service packs in the deployment for 2010, but only up to Version 3 (service pack 2).
I installed sub adv pack first, then service pack 3.1. When I looked on Help/About, I was expecting to see Version 4. Instead I see only Version: D.309.0.0
Is this the same as Version 4?
Matt:
I am not sfore, but we went to 64 bit with C3D 2010 because of stability. Switching to the 64 bit OS has had a substantial reduction in the out of memory messages from Civil 3D and has also reduced crashing in comparision to XP Sp3.
I am our primary C3D support person and I wish I had a specific number for you, but I dont so all I can say is we have seen a SIGNIFICANT reduction in crashing with the change.
HTH
and yes I realize it is still a 32 bit application running on a 64 bit OS. But the ability to maximize the amount of system resorces available has made a difference. I cant wait til we deploy 2012 as a true 64 bit app on a 64 bit OS. Our users who switched OS had a significant reduction in crashes as I mentioned above. We had tried the 3GB switch in XP and still found an improvement when we went to Win7 64bit.
It's just the way it worked out. I was scheduled to get a new 64-bit computer a while back when I started using C3D 2011, but just got around to getting it and setting everything up. I still have a few projects setup with 2010 that are 95% complete and didn't want to switch over to 2011 due to issues with cross sections and such. Once these projects are done, then I'm done with C3D 2010.
