Civil 3D Forum
separate non civil 3d objects in a drawing
6 REPLIES 6
TherealJD
627 Views, 6 Replies
Good morning!
Does anyone know of a way to select all the non-c3d content in a drawing?
I have a really messed up drawing file, and i want to take the non-c3d content in a drawing, and block it out and have it as an x-ref instead.
I was starting to use the quick selection filter, but there's a huge list of entities, lines / polylines / mtext / circles, etc.
Any suggestions?
Cheers,
Jd...
6 REPLIES 6
sboon
in reply to: TherealJD
Perhaps you could do it in reverse.  Use Quick Select to isolate and erase all of the C3d objects, then save the drawing to a new file.  You probably should use the style purge tool also.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
TherealJD
in reply to: sboon
There's an extensive list of C3d objects as well. 😞
Maybe a way to make all civil 3d objects Non-visible, without having to but a non-visible style to each type?
neilyj666
Do you have all the Civil objects on layers starting C- l? If so freeze all the others layers and delete the C- layers
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
tcorey
This code will make a selection set called nonaec:
(defun c:go (/ allobj len ctr ent etyp)
(vl-load-com)
(setq allobj (ssget "All")
len (sslength allobj)
ctr 0)
(setq nonaec (ssadd))
(while (< ctr len)
(setq ent (ssname allobj ctr)
etyp (substr (cdr (assoc 0 (entget ent))) 1 4)
(if (/= etyp "AECC")
(ssadd ent nonaec)
(setq ctr (1+ ctr))
(princ)
);end function
After loading the lisp routine, type Go to make it run. After starting the wblock command, when you go to select objects to export, type !nonaec to have it use the selection set created by the lisp routine. Be sure to use the exclamation mark in front of the selection set name.
Best regards,
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
LyleHardin
in reply to: tcorey
A manual method of selecting the civil stuff is to use the SSX command.  See my command text screen below.
Command: SSX
Initializing...
Type "ssx" at a Command: prompt or
(ssx) at any object selection prompt.
Select object <None>: Return
Enter filter option [Block name/Color/Entity/Flag/LAyer/LType/Pick/Style/Thickness/Vector]: e
>>Enter entity type to add <RETURN to remove>: *aec*
Current filter: ((0 . "*aec*"))
108 found.
This will select all the AEC objects in the drawing and save that selection in memory.
You then Wblock "All" and "R"emove "P"revious (the selection you just made with SSX)  thusly wblocking out all the non-Civil 3D (aec) objects.
TherealJD
Tim / Hardin
Both methods work!
Thanks for the help.
Definitely going to keep this info. I'm sure i'll use it again at some point.
Cheers,
Jd
Rail Community
