Civil 3D Forum
section views and corridor scenarios
13 REPLIES 13
Message 1 of 14
648 Views, 13 Replies
I have created a corridor, surface , sections and
qty, and want to explore another scenario. So I added another baseline, assembly
and targets, and turnes off the baselines from the previous scenario - the plan
looked great, but the first corridor is still in the section view. How can I
turn one off and have the second show? I would have thunk turning off the other
base line would have done that but it doesn't.
I realize I could make another corridor and surface
and add to the section views, but that seems antithetical the the tenets of the
software, no?
Thanks, Joe
Joseph D. Bouza, P.E. (one of 'THOSE' People)
Civil 3D 2008
Win XP
pro
v 2002, sp 2
hp workstation xw4600
Intel Core Duo CPU
E7200
@2.53 GHz
3 GB RAM
NIVDIA Quadro FX 1700
(512MB)
"All Contours are Lies! "-(
AJ)
The mantra of a former Flamer:
If you
are forced to eat an Elephant, don’t complain about it; Take one bite at a
time.
In
memory of the King of Work-arounds
"The only Constant is Change".
"The only thing worse than training your staff, and having them leave is
not training your staff, and having them stay." 😮
A reminder taken
from Graphics Solution Providers' Calendar
page
"An
Equal Opportunity Annoyer" (DK)
13 REPLIES 13
Message 2 of 14
Joe:
Can you select different baselines under Corridor
in "Mr. Prospector"?
Bill
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px"
dir=ltr>
assembly and targets, and turnes off the baselines from the previous scenario
- the plan looked great, but the first corridor is still in the section view.
How can I turn one off and have the second show? I would have thunk turning
off the other base line would have done that but it doesn't.
surface and add to the section views, but that seems antithetical the the
tenets of the software, no?
Thanks, Joe
Civil 3D 2008
Win XP
pro
v 2002, sp 2
Intel Core Duo CPU
E7200
@2.53 GHz
3 GB RAM
(512MB)
AJ)
If you
time.
In
A reminder taken
page
"An
Message 3 of 14
No. Only in the corridor properties dialog
box.
Joe
Message 4 of 14
Save As.
Keep the different scenarios in different
files.
Thunk??  I think you need a, 'woulda' prefix to really make that
work. Winking smile emoticon
John Mayo, PE
Win 7 64, C3D & RD 2010
Core i7 920, 6 GB DDR3
Quadro FX
1700
Message 5 of 14
Right click any of the section view, Section View
Group Properties.
Sections tab
Uncheck what you don't want.
Matt Kolberg
Global CADD Systems - A division of Cansel
dir=ltr>
Thanks, Joe
Civil 3D 2008
Win XP
pro
v 2002, sp 2
Intel Core Duo CPU
E7200
@2.53 GHz
3 GB RAM
(512MB)
AJ)
If you
time.
In
A reminder taken
page
"An
Message 6 of 14
I'll use that advice, but shouldn't turning of
baselines remove any associated sections?
Thanks, Joe
Message 7 of 14
That isn't an option since scenario 2 and scenario
1 are the same corridor. I turned off all the scenario 1 baselines and the
corridor line go away in plan as expected. I add scenario 2 base line and the
corridor line display in plan as expected but scenario 1 stay visible in the
section view even though they are not visible in corridor view.
I thought the hole idea was and I paraphrase from
the marketing material..."...Instantly visualize different scenarios with
civil3d corridors.... blah bla blah..."
momentarily frustrated,
Joe
Message 8 of 14
Duh, of course.  My bad.
What's the problem with making 2 corridors?
it'd be easy then.  You're doing all the same with with the extra baseline
anyway...
Matt Kolberg
dir=ltr>
scenario 1 are the same corridor. I turned off all the scenario 1 baselines
and the corridor line go away in plan as expected. I add scenario 2 base line
and the corridor line display in plan as expected but scenario 1 stay visible
in the section view even though they are not visible in corridor
view.
Joe
Message 9 of 14
I guess that true - I thought I could do it this
way and toggle between scenarios for comparison, plus have less
clutter.
P.S while I have you Matt, are you familiar with
the OverlayEdgetoCrown Assembly? I'd like to add a pavement section and or curb
to the edge but the corridor goes kabluey when I do. the attachenment nodes are
there but it seems to not keep the overlay offset.
I'm going to try a workaround by creating the
overlay surface and extract profile from corridor and the attach a final road
assembly.
Thanks, Joe
Message 10 of 14
MikeEvansUK
Whack the Corridor section 1 and 2 on different Layers, freeze and thaw accordingly or vpfreeze/thaw.
You then won't see them on the sections.
At least that's what I do.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 11 of 14
Do you mean "OverlayCrownBetweenEdges"?
I haven't had the pleasure of experimenting with that one.  What does your
corridor do exactly?  Kabluey?
Matt Kolberg
dir=ltr>
clutter.
curb to the edge but the corridor goes kabluey when I do. the attachenment
nodes are there but it seems to not keep the overlay offset.
assembly.
Joe
Message 12 of 14
Joe-Bouza
I dont have a screen shot handi but if I start with OverlayCrownBetweenEdges it looks perfect but if I attach a curb sub to the edge link the corridor takes on a hour glass shape pattern; every other corridor section collapses on the centerline. For instance sta 1+50 would be 30 feet and 1+75 collapses down where the curb go to the centerline.
Joe
I am a bad speller:
Main Entry: kablooey
Part of Speech: adj
Definition: destroyed, ruined; blown apart; also written kablooie
Your Name
Your Name
Message 13 of 14
Hi Joe,
I haven't needed this sub before either so have no real experience with it.
But I just created a quick assembly & corridor using this, added C & G to
it, and I don't see anything that stands out as being wrong. Would you mind
letting me have a look at your drawing? I may be able to see something that
is being missed, or see that I wasn't applying things the same way as you.
Jeff
miff AT sonic DOT net
"Joe-Bouza" wrote in message news:6391972@discussion.autodesk.com...
> centerline.
> Joe
> I am a bad speller:
> Part of Speech: adj
Message 14 of 14
Joe-Bouza
Hi Jeff, I'll see you on monday.
Thanks, Joe
Your Name
Your Name
Rail Community
