AutoCAD Civil 3D General
Active Contributor
eyescast
Message 1 of 3 (142 Views)
section view -Grid X- & Y values.
142 Views, 2 Replies
10-07-2012 02:08 PM
hello,
the X value which is the section distance, and Y values are elevation.
Y - values how to limit them to 50' range.
X - values 23' range.
thanks
sboon
Message 2 of 3 (137 Views)
Re: section view -Grid X- & Y values.
10-07-2012 03:13 PM in reply to: eyescast
When you create the section views you have the option to limit the width and height, or to allow them to extend to the limits of the sampled data.
BrianHailey
Message 3 of 3 (130 Views)
10-07-2012 03:32 PM in reply to: eyescast
Technically, that's not a section view, that's the corridor section editor (just so others reading this post won't get confused).
To edit the display, go to the ribbon tab Section Editor and on the View Tools panel select the command View/Edit Options. That should get you the settings you are looking for.
http://screencast.com/t/Zb9KhYSJNTct
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
