when i get into my section editor, the view is zoomed out too far. is there a way to change the width of this view? i looked in display options, but may have skipped over the solution.
thanks.
Solved by sboon. Go to Solution.
There should be an option for default zoom scale or factor. Make sure that is set to 1 and see what happens. Something else to keep in mind is that the default view is supposed to include the extents of the corridor section. If you have a targeting error or a bad elevation far away from the baseline then the software will try to show that.
