Civil 3D Forum
rong command come with nil word
6 REPLIES 6
ADAcivil
764 Views, 6 Replies
hi...
i need help
whil working with civil 3d after awhile aproblems appear
for example
i give it command s (stretch) it do QSave or comand C it do copy but i checked command allias and it's ok, some short cuts dosn't work just give me in command line (comannd: nil) and other setting when i change it return back to defult after i close window
so i reinstaled and it worked good but after one day it happen again
any idea why this happen
6 REPLIES 6
wfberry
in reply to: ADAcivil
The only thing that comes to mind is perhaps you are starting the "Autocad Civil 3D as AutoCad".  This means you are using vanilla AutoCAD with no Civil 3D commands.
Bill
ADAcivil
still has the proplem i setupet anti virose and  reinstaled the programe and same proplem pls i need help
ADAcivil
for example if i type ex (extend) here what come
Command: ex
EXPLODE nil
Select object:
or r as redw here what come
Command: r 'REDRAWALL
Command: nil
or s (stretch) here what come
Command: s
QSAVE Save drawing as <C:\Users\a.elmekawy\Documents\Drawing1.dwg>: nil
and that happen awhile after i setup the programe.
so any idea.....??
AllenJessup
Are you running 3rd party software that may be overwriting your Aliases?
Are you sure you are checking - editing the right acad.pgp file? Type (findfile "acad.pgp") at the command line. That will show you the path to the pgp file you're using.
Allen Jessup
CAD Manager - Designer
ADAcivil
sorry but it didn't work and i still have the proplem and it getting me crazy even after i setuped civil 2013
prashant6383
Rail Community
