I have designed a road with crossfall. The RHS is the low side. However at an intersection the LHS should be the low side on this road. I have designed this intersection with LHS low with the junction wizard. How do I now tie in the two corridors so that it transition RHS low to LHS low?
You have to design your own crown transitioning with transition lengths as you see fit per engineering design criteria with your own EOP alignments. In the intersection wizard you have to specify those 'Existing Profiles" for your Edge Profile definitions in the Lane Slope Parameters.
