My drawing coords under toolspace is setup as wv state plane nad 83. My aerial photos and usgs maps are also wv state plane nad83, and are in my drawing.
When I drag and drop in a county boundary which is in UTM nad83 zone 17, it comes in was off. I tried to edit coords and override the UTM with state plane coords under data connect box in mapwspace. I can't get the county boundary to land on my project area.
How do I reproject the county boundary?
sfore wrote:How do I reproject the county boundary?
Try as follows:
1] instead of drag&dropping the shapefile, use the _MAPIMPORT command
2] upon it, declare the entering CRS as "UTM nad83 zone 17" by clicking here:
If everything's all right, your county boundary will be reprojected on-the-fly to Nad83, sir.
I've been out of the office. Anyways I looked at this topic again and tried a few things that you and neilw suggested. I recreated the scenarios from scratch and both suggestions worked, but the first thing I did was open the drawing I worked in last week. When I closed it last week, the boundary was in lala land while my aerials were in state plane. When I opened it today, the boundary was over top of my aerials. It's almost like my session of civil 3d just needed restarted that day for map to recognize the reprojection. That's strange.
I also connected to .shp file thru mapwspace and browsed out to bring it in with no problems. I guess the drag n drop only works sometimes or if the .shp file truely is on the same coordinate system as the drawing. I've read past posts where others have had situations where Map needed restarted. I'm using C3D 2013. I don't recall this problem in past versions.
Thanks for your replies.
