So when I go to assign rendering materials in corridor properties dialog box, it does not allow me to select the box and make a choice of which material, so I am assuming that I am forgetting something...
Solved by tcorey. Go to Solution.
You might be missing the fact that you have to Edit Current Select to modify your Code Set Style. You cannot edit it directly in the window on the Codes tab of Corridor Properties.
Tim
