Civil 3D Forum
red circle and pencil or "Locked"? symbol in point list
7 REPLIES 7
Message 1 of 8
kevin
5200 Views, 7 Replies
We have been bringing points directly into a 2012 Civil 3d drawing using the same method for quite a while.  We use a numeric descriptor code and the points are filtered correctly.  In this particular drawing, one description code was singled out and "locked" in the drawing.  The points and symbol show in the drawing slightly muted but when I try to edit the points I am unable to do so.  I have tried the "unlock" command with no result.  The symbol displayed by the point number is a red circle over a pencil.
Any thoughts???
7 REPLIES 7
Message 2 of 8
Jeff_M
in reply to: kevin
Kevin, the "Autodesk Discussion Groups Feedback" Forum is for feedback regarding the forums. There is a Civil3D specific forum, thet the moderator will be moving this to, where you can ask your C3D questions. AutoCAD Civil 3D - Autodesk Discussion Groups This link will show you the 3 associated forums.
Oh, and welcome to the forums!
Jeff_M, also a frequent Swamper
Message 3 of 8
troma
in reply to: kevin
Right-click the point > Edit points.
In the panorama right-click the point > Unlock.
Or is that what you already did?
Mark Green
Working on Civil 3D in Canada
Message 4 of 8
kevin
in reply to: kevin
Yes,  it does not allow me to edit the point that way.
Message 5 of 8
rddarger
in reply to: kevin
I had the same thing happen and I found that my layers were frozen and locked. Just Thaw and unlock layers and you have access to your points.
Message 6 of 8
in reply to: kevin
Right click on point group - open properties
under information tab, uncheck object locked
Message 7 of 8
in reply to: kevin
The layer that the point is in may be locked.
Message 8 of 8
cvannest
in reply to: rddarger
Thank you, that was the fix for me.
Rail Community
