Civil 3D Forum
raise lower survey
12 REPLIES 12
Message 1 of 13
ryan.beisaw
752 Views, 12 Replies
raise lower survey
I need to lower my survey to a specific elevation. I can lower the surface by this increment, but i dont see the point elevation change. Id like to make sure everything changes (points, surface, figure lines, etc.) Can someone explain how to make sure I get everything lowered to a specified elevation? Thanks....
Ryan B
12 REPLIES 12
Message 2 of 13
sjg
in reply to: ryan.beisaw
I believe you just need to translate the survey database. There will be no movement or rotation of the database just a vertical change.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
Message 3 of 13
Joe-Bouza
Qselect >>all, Move 0,0,0 >>0,0,<delta> or edit the points by datum
Joe Bouza
Message 4 of 13
ryan.beisaw
in reply to: sjg
thanks, I ended up translating the survey database in elevation only and it worked just the way i needed it to. appreciate the help!
Message 5 of 13
tcorey
in reply to: Joe-Bouza
Yikes, dangerous. Qselect all? Do you want to move every line, text, point, corridor and alignment up or down? Probably not.
Steve hit the nail on the head. Kudos, Steve.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 6 of 13
Joe-Bouza
in reply to: tcorey
No. The assumption is we are dealing with all the civil3d objects
Joe Bouza
Message 7 of 13
wfberry
So, what happens Joe, when you move all the points and the surface?  (consider that the points made the surface).
Bill
Message 8 of 13
Joe-Bouza
in reply to: wfberry
The data, Bill. The data.
I beg all your pardons if I miss spoke - or have said something that cant be determined by reading between the lines. we all know by now my prose at times intentionally diverts the readers attention from the point. my hopes are to open eyes. If I'm wrong I'm wrong. I don't see anything in the OP about a surface - Just data. So if you lower all the data what will happen, Bill?
Joe Bouza
Message 9 of 13
Jeff_M
The OP stated "I can lower the surface by this increment, but i dont see the point elevation change. Id like to make sure everything changes (points, surface, figure lines, etc.)". So if you lower the points AND the surface, the surface will be lower than the points defining it.
Message 10 of 13
Joe-Bouza
in reply to: Jeff_M
That appears to be a qualifying statement to the prepositional phrase preceding it. My interpertation was the data needed to be adjusted.
And that's why I clarified with "Data".
Seems Like I shall be hoisted on my own petard. Simply for using the word "All". It appears that this has provoked the ire of my soldiers in arms. Don't really know why? Lowering the data seems like a viable solution to me. But hey, I'd never say I know it all - just trying to help out.
Joe Bouza
Message 11 of 13
ryan.beisaw
Basically I had a small survey that had been performed using an assumed coordinate system/datum (10000,10000,100.00)
I wanted to tie it vertically to a benchmark that had been located (NO horizontal shift/rotation)
the surface and the existing site conditions had already been prepared using linework coding in the field. When I selected the surface to lower to the benchmark, that was the only civil objec that adjusted(i assumed the points would as well seems how the surface was created from the points, right?)
Thats why I asked the question, to adjust all the survey data to the lower benchmark elevation. I didtn want to leave any survey data behind at the assumed 100.00 elevation it started at.
The translation worked perfectly, I had just not performed that operation yet in civil 3d 🙂
Thank you all for you input, much appreciated and these forums continue to provide the ultimate feedback 🙂
Ryan B
Message 12 of 13
tcorey
Joe, please don't feel you're being attacked by your fellows. We value your extensive knowledge and willingness to participate here.
To all, the reason I posted regarding the use of Select All: From my perspective, knowing how many inexperienced users are out there, I would avoid suggesting Select All without knowing the complete situation. Firstly, what layers are on/thawed. Many users do not consider the consequences of input before they use it. An experienced user would think ahead before he performed this operation, but I can hear the phone call coming in to tech support, "It said on the discussion thread to Select All and Move. I don't understand why my text is at -100 elevation now."
The suggestion to move the data is valid, although not the best answer for this particular poster. It appears that he was talking about data he had brought in using Civil 3D Survey. In that case, Translate Survey Database is the best option. It will not affect drawing objects other than Survey Points and Figures, and it keeps a record of the operation. Unless you keep an AutoCAD log file, there is no way of tracing a Move operation.
Best regards,
Tim
Tim Corey
Redding, CA
Message 13 of 13
Joe-Bouza
in reply to: tcorey
Thanks, Tim. I'm not going anywhere.
Joe Bouza
Rail Community
