Sounds simple enough if you know how to program excel to calculate the
coordinates from the geometry given. Save as an ASCII (txt) file. (1,
251.36, 589.39, Elevation). Pt #, Northing, Easting, Elevation or Pt# , X,
Y (X, Y = Easting, Northing, however)
It depends on how many points. It you just had a few rotate a line your
angle (Degrees) and extend the distance and you have your point location.
Bill
wrote in message news:6232128@discussion.autodesk.com...
I have an excel spreadsheet with angle from north and distance in feet; each
in a column. The data is from a total station and will be used for a very
basic survey. Is there an easy/ direct way to load these points in autodesk?
All points were taken from a single survey location.
