I got a response from tech support that indicates a new mill report will be available in 2011. This did not answer the question about what is available right now in 2010. Here's my question more specifically w/ attached documents:
Attached are a few highlighted pages of C3DStockSubassemblyHelp.pdf, assembly documentation that comes with C3D 2010. Overlaymillandlevel1 and overlaymillandlevel2 provide "milling or leveling as needed" (p. 14). Page 363 shows the coding diagram for the assembly I'm using, with codes for both a milling and leveling case indicated. HOWEVER, in practice only the milling links appear in the code set, even if codes are imported from subassembly, assembly or corridor. FURTHERMORE, the section views (see example attached) show an area that is quantified as "mill" (in volumes/quantity takeoffs), regardless of whether its is mill or level case; AND a "double dipping" by having quantities for cut/fill in mill/level areas. MY SPECIFIC QUESTION: Why does there not appear to be a CODE for "level" which could be quantified (in addition to milling) as indicated in the documentation?
