AutoCAD Civil 3D General
Active Contributor
Message 1 of 6 (185 Views)
"hanging-up" when creating surface from polylines
185 Views, 5 Replies
05-19-2011 10:23 AM
I've created several surfaces by tracing contours on a xref, assigning elevations. Then through the surface definitions in the prospector add the contours I've traced.... This time it doesn't work... It just hangs up and gives me the busy symbol.. I've let it run for an hour over lunch and it still did not create the surface...I'm stumped
AllenJessup
Message 2 of 6 (182 Views)
Re: "hanging-up" when creating surface from polylines
05-19-2011 10:43 AM in reply to: kentanner1346
I don't know if this is definitely the cause. But I'd suggest using the Map Drawing Cleanup tools to make sure you didn't accidentally create a coincident vertex in one of your polylines.
Allen
Active Contributor
Message 3 of 6 (177 Views)
05-19-2011 11:20 AM in reply to: AllenJessup
I am unfamiliar with Map Drawing Cleanup tools, I don't even know how to access them..
Active Contributor
Message 4 of 6 (173 Views)
05-19-2011 11:33 AM in reply to: kentanner1346
It seems if I explode the Polyline then do a 'pedit' command and 'join' the segments it works ... I have a lot of contours to do this to. So I'd still like a more timely method.
AllenJessup
Message 5 of 6 (168 Views)
05-19-2011 12:03 PM in reply to: kentanner1346
Search Map 3D Documentation for "Drawing Cleanup" of "Cleanup Actions. Specifically you're looking to "Snap Clustered Nodes".
Allen
AllenJessup
Message 6 of 6 (163 Views)
05-19-2011 12:06 PM in reply to: kentanner1346
That may indicate that Map Cleanup would help.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
