AutoCAD Civil 3D General
neilyj
Message 1 of 3 (160 Views)
"Ghosting" in paper space
160 Views, 2 Replies
01-09-2013 08:00 AM
Since installing SP1, I have noticed "ghosting" when panning/zooming in paperspace i.e. the original image is still visible. The only solution I have found is to turn off Hardware Acceleration and then turn it back on.
Has anyone else experienced this??
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 UKIE SP1 & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
Valued Mentor
hardin
Message 2 of 3 (158 Views)
Re: "Ghosting" in paper space
01-09-2013 08:06 AM in reply to: neilyj
Yes, we have a few machines around here that do that on occasion. We also have found turning off or on Hardware acceleration takes care of it.  All our machines are identical and it only seems to happen on some drawings. We've tried swapping video cards, re creating the viewports etc. Cycling the Hardware Acceleration seems to be the best solution. It's gotta be a video driver bug of some sort, I think.
Learn, Practice, Get Better
http://autocad-lkh.blogspot.com
Distinguished Contributor
Message 3 of 3 (73 Views)
09-23-2013 11:18 PM in reply to: neilyj
mm.. we have users with the same problem.
Hardware accelation on/off does work however we also found that if you change the layout regen options it works as well, plus its permanent. however switching to regen mode makes layout switching slower!
can't belive there is still no solution to this..
Civil 3D 2014 (SP1)
Win 7 Pro x64
DELL Precision Workstation T3500
Intel Xeon 3.3GHz (w3680)
24Gb Ram
NVIDIA Quadro 2000 (1GB)
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
