Civil 3D Forum
"Fatal Error: Unhandled Access Violation Writing 0x0000 Exception at 0h""
30 REPLIES 30
Message 1 of 31
121150 Views, 30 Replies
I get the above error when I attempt to open Civil 3d 2013
Tags (1)
30 REPLIES 30
Message 21 of 31
AllenJessup
@Anonymous wrote:
"I have just installed Autocad LT 2013 (license bought yesterday) on a new Lenovo E330 laptop and the first time I'm trying to run Autocad I'm getting the following error: "fatal error: unhandled Access violation writing 0x0000 exception at 0h".
If you've just installed it. Try posting to the Installation & Licensing group. You may get some help there.
Allen Jessup
CAD Manager - Designer
Message 22 of 31
hgohel
If you aren't able to update the USB graphics device driver, then the next best thing to try is to uninstall those drivers, reboot and then try to launch AutoCAD or Civil 3D.
BTW, which USB graphics device are you using?
Himanshu Gohel
Message 23 of 31
thanks bro..... 😛 🙂
Message 24 of 31
I have this same problem and tried all of the opyions, can anyone tell me if it also works on windows 8??? and autocad 2014. please help!!!!
Message 25 of 31
hgohel
Best course of action is to send in a CER (crash) report with your email address and then open a subscription support case with details and inform them that you have submitted a crash report.
Himanshu Gohel
Message 26 of 31
in reply to: hgohel
I had this problem happen to me just randomly showed up one day when I went to open a file.  Now it happens anytime I try and open a file within AutoCAD or through Windows Explorer.  I was able to fix the problem by setting the application defaults, but this lost all of my customizations I had before.  I selected the option to save my customizations to a file and I have tried attached the file here but it is apparently too large.  Is there a way to figure out what is causing the problem and removing/fixing this so I can reinstall my custom settings?
Message 27 of 31
bmvp
Hi there.
I have this error too, when i´m trying to save a file, that is in a sheet manager. I´m using a civil 3d 2015 in a windows 7 64 bits. Any help. Thank you.
Message 28 of 31
I get the above error when I attempt to open AutoCAD 2015
Message 29 of 31
AllenJessup
Welcome to the forum. Those types of error are not to helpful. However I did find THIS in the Knowledgebase. See if that helps.
Allen Jessup
Message 30 of 31
Hello Team,
Can we get any update on this error?
Babu
Message 31 of 31
hgohel
@Anonymous
The error message posted is too generic to have one solution, and being a four year-old thread, it may not be applicable to newer versions of Civil 3D.
If you are running into this error, I suggest you start a new thread with a description of the error, what you were doing when you ran into the error, and information about which version of Civil 3D, along with information about your graphics card and driver versions.  If you do get a CER window, please send in a crash report so that it can be associated with your thread as well.
Thanks.
Himanshu Gohel
Rail Community
