hey everyone....
I have created 2 surfaces. One is exising ground, and the other is a final surface. I would like to do a couple of cross sections across my area, and show the 2 different surfaces in the sections. Where do I start? THis is not a road project, but do I need an alignment or is there a quick section I can do? Thanks for any help. I know these are simple questions, but I am just learning this stuff.
MKH
I would create an alignment exactly where you want your section, then create a surface profile for the alignment and include both surfaces. Works like a charm, takes maybe 60 seconds to do.
If you just want to have a quick look and don't want to save the profile, you can go to the analyze tab, ground data and pick quick profile.
....... and you can explode the Quick profile so it will remain in the drawing (no longer dynamic though)
neilyj (No connection with Autodesk other than using the products in the real world)
Its Quick Profile, not Quick Section
