AutoCAD Civil 3D General
Active Member
Message 1 of 2 (74 Views)
quick elevation edit trouble
74 Views, 1 Replies
10-22-2013 12:45 PM
I've creaetd feature lines and made them breaklines on the surface.  When I go back to use the quick elevation edit tool to change an elevation at either where I've previously put a PI or elevation point I don't get the triangle cursor so i'm not able to select and change the elevations  The slope triangle between elevations isn't showing up either.  It's not every feature line in the drawing, only some and i've been able to manipulate all of them in the past.  I've removed the feature line and redrawn them but got the same results.  Any suggestions?
Message 2 of 2 (59 Views)
Re: quick elevation edit trouble
10-22-2013 03:12 PM in reply to: BrianD17
You need to make sure that the site is set properly in the Quick Elevaiton Edit tool.  The triangle shows only on feature lines on the same site that is currently set.  Look at the command line after you've started the QE tool.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
