AutoCAD Civil 3D General
Active Contributor
jeffjensen
Message 1 of 4 (4,047 Views)
publishkml - export civil 3d 2012 points to google earth - not working
4047 Views, 3 Replies
01-17-2012 12:56 PM
Hello Civil 3D Users,
I'm unable to get the PUBLISHKML to display Civil 3D Points (both the point style and the point label style) in Google Earth. It appears to be a bug but I wanted to check to see if anyone else had success with this.
Note, I'm able to assign a stateplane coordinate system and successfully import the Google Earth image. I then create a few Civil 3D points, everything looks good, but when I run PUBLISHKML, it creates the KML / KMZ file but nothing is displayed in Google Earth.
thanks for your assistance,
Jeff Jensen
antoniovinci
Message 2 of 4 (4,014 Views)
Re: publishkml - export civil 3d 2012 points to google earth - not working
01-19-2012 03:12 AM in reply to: jeffjensen
Good point, sir.
The only workaround I can suggest, it's to _CONVERTPOINTSTOSDSKPOINTS all your Cogo points, then explode everything many times unitl you get simple Autocad points.
Then, you _MAPEXPORT those Acad points to a shapefile, on-the-fly converted to LL84 i.e. EPSG:4326
Finally, you transform that shapefile to KML, by using one of the third-party converters, like this one.
Active Contributor
jeffjensen
Message 3 of 4 (3,957 Views)
02-06-2012 12:02 PM in reply to: antoniovinci
Thanks for the reply Antonio.
Here is an update on what I found out.
The Civil 3D 2012 Users Guide - Publishing Civil Data to Google Earth (http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/empty_concept_1234-2341.htm) briefly discusses exporting to Google Earth. I'm guessing Civil 3D Points are not considered Civil Data and that is the reason why its not supported in the Google Earth export. Go figure.
As a workaround, I used Trimble Business Center (http://www.trimble.com/tbc_ts.asp?Nav=Collection-36339) to export my GPS points into Google Earth. It was a pretty painless process.
Lastly, I was also looking at Safe Software's FME (http://www.safe.com/solutions/for-applications/autodesk/autodesk-autocad-civil-3d/) as it supports reading Civil 3D point data (http://docs.safe.com/fme/reader_writerPDF/civil3d.pdf) but I found the Trimble Business Center approach more intuitive for a single points file conversion.
Jeff Jensen
Jeff_M
Message 4 of 4 (3,953 Views)
02-06-2012 12:19 PM in reply to: jeffjensen
Sorry I missed your original post on this. There is another option available which works inside C3D: EXPORTKML
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
