AutoCAD Civil 3D General
Distinguished Contributor
annw2
Message 1 of 8 (577 Views)
profiles switch dynamic to static?
577 Views, 7 Replies
06-06-2011 11:17 AM
Hello:
Just updated my alignment by erasing several hundred feet from the beginning.  Looked at a plot and the profile didn't update.  Checked status of profile and it said static and surface imported from LDD had disappeared.
Profile had been dynamic last month.
Is it a feature that if a surface is accidently erased, the associated profiles switch to static?
Anybody have any clues?
Ann Wingert, P.E.
josephbouza5497
Message 2 of 8 (564 Views)
Re: profiles switch dynamic to static?
06-06-2011 12:44 PM in reply to: annw2
I just tried deleting a surface and the profile reverted to static. I guess thats better than deleting the profile with the surface.
Employee
hgohel
Message 3 of 8 (535 Views)
06-07-2011 07:58 AM in reply to: annw2
Yes, that is correct.  If the surface that a profile is dependent on is not available any more, the profile changes to static mode.  As Joe observed, the other alternative would have been to delete the profile when the surface is deleted.
If the surface is available in the drawing again you may be able to change the profile back to dynamic mode.
Himanshu Gohel
Autodesk, Inc
annw2
Message 4 of 8 (525 Views)
06-07-2011 09:49 AM in reply to: annw2
I tried toggling the profiile back to dynamic when I brought the surface back in.  It wouldn't give me the option.  Wish list for 2013?
Next wish list item - Big warning - :smileyvery-happy:eleting the surface will convert profile to static" if a surface is to be erased from a file.
I must have deleted the surface by accident.
Ann Wingert, P.E.
josephbouza5497
Message 5 of 8 (522 Views)
06-07-2011 10:42 AM in reply to: annw2
would you prefer that the profile be deleted? If it will not go back to dynamic - resample it
annw2
Message 6 of 8 (510 Views)
06-07-2011 03:31 PM in reply to: annw2
I did.  I fixed the problem.
I prefer the profile to go to static rather than be deleted.  I just prefer a warning before deleting a surface with a profile attached.
Ann Wingert, P.E.
*Expert Elite*
klugb
Message 7 of 8 (502 Views)
06-07-2011 07:01 PM in reply to: annw2
A good check is to rt-click on it in prospector and see if "delete" is an option. If not, it's still being referenced. The fun part is finding what is using it.
Bruce Klug
AutoCAD Expert Elite
AutoCAD Civil 3D 2014 Certified Professional
Infrastructure Design Suite 2014 (SP1)
Testing Civil 3D 2015
Win 7 Pro, 64-bit
annw2
Message 8 of 8 (493 Views)
06-08-2011 09:55 AM in reply to: annw2
Could which profiles, etc. that are using the surface be added to the properties information?
I think that would be a very helpful additiona in 2013
Ann Wingert, P.E.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
