AutoCAD Civil 3D General
Active Member
JAMIEMACINNIS2159
Message 1 of 8 (675 Views)
profile without a surface?
675 Views, 7 Replies
03-04-2010 12:31 PM
Is it possible to create a profile view without a surface model?
I have a series of survey shots going straight up the center of the road that I would like to create a profile with.
can that be done?
Jamie
Active Contributor
frye_guy
Message 2 of 8 (671 Views)
Re: profile without a surface?
03-04-2010 12:36 PM in reply to: JAMIEMACINNIS2159
http://civil3dnovice.blogspot.com/2008/09/create-profile-without-surface.html
This worked for me.
*James Wedding, P.E.
Message 3 of 8 (673 Views)
03-04-2010 12:37 PM in reply to: JAMIEMACINNIS2159
That will work in 2009, not in 2010, and again in 2011.
HTH
JW
Valued Mentor
awood
Message 4 of 8 (672 Views)
03-04-2010 01:06 PM in reply to: JAMIEMACINNIS2159
Hi Jamie,
I did this just recently with a different workaround on a project with only centerline of road shots.
You do create a surface model, create it from those centerline points.
Run an alignment through them (the Subscription Advantage pack tool => Create Best Fit Alignment works great for this).
Then you can get a profile.
HTH
AWood
Valued Contributor
gauss2069
Message 5 of 8 (671 Views)
03-04-2010 01:07 PM in reply to: JAMIEMACINNIS2159
..again in 2011? Oh! this is March.......
Civil 3D x64 2013
Win 7 x64
Intel Core i7-940XM
8 GB RAM
Quadro FX 5000M
Message 6 of 8 (671 Views)
03-04-2010 01:18 PM in reply to: JAMIEMACINNIS2159
Yes, and since Matt Osborn was kind enough to mention it publicly the
other day, I don't feel too bad about repeating it.
On the other hand, anything else that might be in the upcoming release
I'd have to be mum on.
JW
*Matt Kolberg
Message 7 of 8 (672 Views)
03-05-2010 08:40 AM in reply to: JAMIEMACINNIS2159
This is very easy.
1. make an alignment along those points.
2. make the profile view and specify manual elevations.
3. connect those points with a feature line, make sure it snaps to the Z of
those poiints.
4. "project that feature line into the profile view.
Matt Kolberg
Global CADD Systems - A division of Cansel
"JAMIEMACINNIS2159" wrote in message news:6348967@discussion.autodesk.com...
> can that be done?
> Thanks
> Jamie
*Expert Elite*
Civil3DReminders.com
Message 8 of 8 (673 Views)
03-05-2010 09:30 AM in reply to: JAMIEMACINNIS2159
If you want to do a little prework to automate the process: http://blog.civil3dreminders.com/2008/09/create-profile-without-surface-vba.html
Civil Reminders
http://www.CivilReminders.com/
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
