Civil 3D Forum
profile without a surface?
7 REPLIES 7
Message 1 of 8
JAMIEMACINNIS2159
4070 Views, 7 Replies
Is it possible to create a profile view without a surface model?
I have a series of survey shots going straight up the center of the road that I would like to create a profile with.
can that be done?
Jamie
7 REPLIES 7
Message 2 of 8
http://civil3dnovice.blogspot.com/2008/09/create-profile-without-surface.html
This worked for me.
Message 3 of 8
in reply to: JAMIEMACINNIS2159
That will work in 2009, not in 2010, and again in 2011.
HTH
JW
Message 4 of 8
awood
Hi Jamie,
I did this just recently with a different workaround on a project with only centerline of road shots.
You do create a surface model, create it from those centerline points.
Run an alignment through them (the Subscription Advantage pack tool => Create Best Fit Alignment works great for this).
Then you can get a profile.
HTH
AWood
Message 5 of 8
..again in 2011? Oh! this is March.......
Civil 3D x64 2013
Win 7 x64
Intel Core i7-940XM
8 GB RAM
Quadro FX 5000M
Message 6 of 8
Yes, and since Matt Osborn was kind enough to mention it publicly the
other day, I don't feel too bad about repeating it.
On the other hand, anything else that might be in the upcoming release
I'd have to be mum on.
JW
Message 7 of 8
This is very easy.
1. make an alignment along those points.
2. make the profile view and specify manual elevations.
3. connect those points with a feature line, make sure it snaps to the Z of
those poiints.
4. "project that feature line into the profile view.
Matt Kolberg
Global CADD Systems - A division of Cansel
"JAMIEMACINNIS2159" wrote in message news:6348967@discussion.autodesk.com...
> can that be done?
> Thanks
> Jamie
Message 8 of 8
If you want to do a little prework to automate the process: http://blog.civil3dreminders.com/2008/09/create-profile-without-surface-vba.html
Civil Reminders
http://www.CivilReminders.com/
Rail Community
