AutoCAD Civil 3D General
Distinguished Contributor bf
Message 1 of 4 (146 Views)
profile structure doesn't update 2011
146 Views, 3 Replies
10-03-2012 12:51 PM
profile structure doesn't update when changed.  First, the rim to sump value will not change with sump defined by depth and trying to change the sump depth (going deeper and no rules exist).  Second, change to define sump by elevation and the sump elevation changes and the grip changes to the correct elevation, but the part outline doesn't change.  I've read where the part catalogue location should be updated.  I did.
Message 2 of 4 (116 Views)
Re: profile structure doesn't update 2011
10-04-2012 08:59 AM in reply to: bf
thanks a lot autodesk
*Expert Elite*
Jeff_M
Message 3 of 4 (115 Views)
10-04-2012 09:42 AM in reply to: bf
This is a peer to peer forum where we, as users, try to help other users, in our spare time. Yes, sometimes we get the Autodesk folks in here, but we are mostly just users like yourself. For your non-updating structure, I've had cases like that, where a quick Swap part fixed it...swap it for another part type, then swap it back to the correct one.
Jeff_M, also a frequent Swamper
Message 4 of 4 (108 Views)
10-04-2012 01:14 PM in reply to: Jeff_M
It was a swipe at Autodesk in general.  At times I do not like this program very much.  I had tried swapping parts, alas, to no success.  I've looked at every setting for structures, profile views, viewports, pipes, trees, shoes...nothing.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
