Civil 3D Forum
profile grade label reset
6 REPLIES 6
nostupidquestions
388 Views, 6 Replies
i've got a profile with a lot of grade labels, some of which i've turned the visibiliy off. i need to turn some, but not al,l of them on. how does one do this?
Intel(R) Xeon(R) W-2245 CPU @ 3.90GHz 3.91 GHz
64 GB RAM
C3D 2023.2
6 REPLIES 6
Don't know if this will work..
Select one, right-click and choose select similar. Hopefully you will see grips for the hidden ones. If you do, deselect the ones you do not want to modify.
John Mayo
wfberry
in reply to: nostupidquestions
Existing ground or New Profile?
Bill
nostupidquestions
in reply to: wfberry
it's a new profile. i can grab the grip of the one that is missing but there aren't any options to make it visible.
64 GB RAM
C3D 2023.2
Once the visibility is turned off it seems there is no way to select it again. I think you are going to have to use the Reset All Label Groups and then hide the ones you don't want again.
Other options I see...
The weeding function in the Profile Labels dialog can limit the number of grade labels.
Use a grade label with the leader turned off and drag the unwanted labels out of the plot view so the can be reset if desired.
Wish they were better solutions.
John Mayo
that's what i figured. it's a shame they can't make it like all the other line labels with labeling a single segment or multiple segments. thanks.
64 GB RAM
C3D 2023.2
troma
For next time, I recommend this:
Make a 'no-plot' label. That could show up on a no-plot layer, or it could be a label with the display set to false in the label style. (I made them on a no-plot layer and with very small text height.)
Then, when you want to turn some labels off, switch them to this style rather than setting their visibility off or deleting them. This way you can always switch them back again if you need them.
Doesn't help you now of course, and I agree that there should be a better way of handling this.
Mark Green
Working on Civil 3D in Canada
Rail Community
