Our company has created some blocks with attributes and when using the move command with these blocks when it asks you to pick the second point of placement, I can no longer visually see the block, but when I save and then exit the drawing and get back in, the block is there....anyone else have this issue when using the move command?
Solved by wbrustle. Go to Solution.
How do you turn on hardware acceleration? Yes I have tried regen and it makes it worse. Actually, after the regen command all my graphics disappear and I can no longer see anything on my screen anymore...but as soon as I save, exit my drawing and get back in, everything is normal again.
I just tested something else in the drawing, it seems to happen when I move the block only the first time. Once I save, exit and re-enter drawing, that block that is now on my screen again seems to move all over the place with out a problem.
thank you Jay......that seemed to work!! What exactly does turning the hardware acceleration on and off do? Should I always leave it on?
