Civil 3D Forum
points
9 REPLIES 9
Message 1 of 10
wbrustle
618 Views, 9 Replies
points
What is the difference between moving or rotating points manually and using survey translate database to move or rotate points?
9 REPLIES 9
Message 2 of 10
BrianHailey
in reply to: wbrustle
The translate option will only work on points that are in a survey database and the move/rotate option will only work on points that aren't in a survey database (unless you know a few tricks).
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 3 of 10
wbrustle
in reply to: BrianHailey
ok I understand, but if I were to unlock the points from the survey database, then the move & rotate command would work?
Message 4 of 10
BrianHailey
It will work for the points in the drawing but not the database. You would have to update the database after the move/rotate.
GEI Consultants
My Civil 3D Blog
Message 5 of 10
wbrustle
ok thanks for your help!
Message 6 of 10
gk
Brian - is there an easy  way to update the survey database if you were to adjust the points in the drawing ?
Garry Kingsley
GarryK
Message 7 of 10
tcorey
in reply to: gk
Erase the points from the database and then do another Import Event, importing from the drawing.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 8 of 10
wbrustle
in reply to: tcorey
I was wondering that same question about updating the database from edits made from the points in the drawing. Our field guys usually always start their work on an assumed datum in the field and then once they import fieldbook in the drawing make adjustments to the points and I was wondering the same thing on how to update the database, but how do you import events from the drawing to the database?
Message 9 of 10
tcorey
When you perform the Import Event, on the Data Source page, change the Data Source Type to Points from Drawing.
Tim Corey
Redding, CA
Message 10 of 10
wbrustle
in reply to: tcorey
thank you sooo much. I have been wondering how to do that!!!!
Rail Community
