Civil 3D Forum
point label style/spot elevation style
5 REPLIES 5
ryan.beisaw
1714 Views, 5 Replies
I am trying to create a label style that will show me the point elevation and also the difference in elevation to the surface. I cant figure out how to get the text component to do this. Also if it should be done through a point label style or a surface spot elevation label. Has anyone done that before? Help would be greatly appreciated!
5 REPLIES 5
_Hathaway
in reply to: ryan.beisaw
Sincpac is the way to go if you want this type of data and interaction.  While sincpac will not put this in a note form(at least not that i'm aware of) you can easily create a spreadsheet which lists differences between multiple points, point groups and multiple surfaces.
Look into using expressions, then put the expression into the label.
This post may answer your question
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Get-an-elevation-difference-between-Points-an...
Unfortunatly I to get this label without this work around you would probalbly have to combine something life Reference Text in an Expression - which you can't do. You can get a Spot Elevation label to show a point elevation in it using Reference Text, but not the difference.
The volume surface is the way to go as described in the above post.
ryan.beisaw
Thats why i assume it has to be done through the point label style. I can copy the component for the point elevation but i dont see where i can take the point elevation and subtract the surface elevation at that point
ex. [point elevation]-[surface elevation]
surface elevation isnt an available option in dealing with the point label style
hmmm....
murray-clack
Here are two tutorials that work great:
Part 1:  https://www.youtube.com/watch?v=mBWMgN4YPJU
Part 2: https://www.youtube.com/watch?v=oE2jdZKY-Ng
Rail Community
