I took the following point file into my drawing using the survey import. It will crash C3D 2103 everytime if I process linework. Can someone verify this for me?
1,5551.9964,5352.9989,251.670,EP BEG BC H0.1 V0.5 H0.5 H25 V2
2,5513.9965,5390.9997,249.637,EP
3,5551.9963,5428.9989,247.604,EP
4,5589.9964,5390.9999,249.637,EP RPN1 EC
It works fine for me using the Sample linework code set. No crash.
Really? I had to change the EP BEG BC H0.1 TO H0.5 or greater. It does not like the 0.1 for some reason when processing linework.
Jeff,
Shouldn't the "BC" portion of the description begin a curve? Your figure doesn't have any curves on it. I don't have C3D on this system so I'll have to try it out later.
That looks better. Didn't notice the change in the begin code. If I remember correctly, the begin code in field book files is BEG so it makes sense as to why that was used here. That's one nice thing about the Linework Code Sets, you can set the codes to whatever you want.
