is there a way to create points using latitude and longitude. i have some borehole to be located on my project and the location information was given to as latitude and longitude.
thanks
jason m.
Solved by jmatte2004. Go to Solution.
Solved by mathewkol. Go to Solution.
Glad to help.
After the 'LL can you change the input format on the command line to input decimal degrees. What format is it asking for?
