Civil 3D Forum
point creation
5 REPLIES 5
jmatte2004
652 Views, 5 Replies
point creation
is there a way to create points using latitude and longitude. i have some borehole to be located on my project and the location information was given to as latitude and longitude.
thanks
jason m.
5 REPLIES 5
mathewkol
in reply to: jmatte2004
Yes. There is a transparent command 'LL, when asked to pick the location of a point, you can use.
Your drawing of course needs to have a coordinate system set or this will be impossible.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Jeff_M
Sure. If you have a file with the information you can create a PointFileFormat which uses Lat/Long. Or, you can create points and enter the values manually: Help file
jmatte2004
the transparent command worked great
mathewkol
Glad to help.
Matt Kolberg
kstarnes
in reply to: mathewkol
After the 'LL can you change the input format on the command line to input decimal degrees. What format is it asking for?
Rail Community
