AutoCAD Civil 3D General Discussion
JDESILVA
Message 1 of 10 (1,284 Views)
Accepted Solution
plotting to pdf using Autocad Civil 3d 2013
1284 Views, 9 Replies
04-09-2013 12:22 PM
Hi.
I'm having a problem plotting to pdf (using ScanSoft Pdf Pro 4) causing Autocad Civil 3d: Infrastructure Design Suite.
When I plot in Civil 3d 2009 I have no problems but we recently switched to Autocad Civil 3d: Infrastructure Design Suite and when I try to plot a pdf 24x36 it looks correct in the plot preview but my final pdf size comes out 36x36.  I have tried everything I know...
Create a new sheet size
Rotation
No luck on figuring out what the problem is.  I can't just save as an earlier version and plot in C3d 2009 because my alignments gets screwy.
J
Product Support
AlmasSuljevic
Message 2 of 10 (1,233 Views)
Re: plotting to pdf using Autocad Civil 3d 2013
04-11-2013 06:53 AM in reply to: JDESILVA
Hi JDESILVA,
Do you have the same issue is you plot using DWG to PDF.pc3?
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
JDESILVA
Message 3 of 10 (1,208 Views)
04-11-2013 12:42 PM in reply to: AlmasSuljevic
Yes I have.  NO luck
Product Support
AlmasSuljevic
Message 4 of 10 (1,200 Views)
04-11-2013 12:59 PM in reply to: JDESILVA
Can you post your drawing? I would like to try it.
Almas Suljevic
Autodesk, Inc.
JDESILVA
Message 5 of 10 (1,185 Views)
04-11-2013 03:59 PM in reply to: AlmasSuljevic
Please see attached
JDESILVA
Message 6 of 10 (1,185 Views)
04-11-2013 04:00 PM in reply to: AlmasSuljevic
Please see attached
Product Support
AlmasSuljevic
Message 7 of 10 (1,163 Views)
04-12-2013 05:59 AM in reply to: JDESILVA
Hi JDESILVA,
I opened your drawing and and it shows a box with sides 22x36 when I measured it, but the page shows 8.5x11. In PAGESETUP I was able to set the Paper size ARCH expand D (24.00 x 36.00 Inches) and use DWG to PDF.pc3. It all came out nice. Please open this drawing and review the settings to see if you can mimic it on your machine.
Almas Suljevic
Autodesk, Inc.
JDESILVA
Message 8 of 10 (1,141 Views)
04-12-2013 11:26 AM in reply to: AlmasSuljevic
Almas,
That worked, Thanks. But I usally use ScanSoft PDF Create to make my pdf's.  Works fine in C3d 2009.  How would I go about creating a 22x36 paper to use DWG to PDF.pc3? That's the sheet size we use in Hawai`i.
Thank you,
Product Support
AlmasSuljevic
Message 9 of 10 (1,136 Views)
04-12-2013 11:33 AM in reply to: JDESILVA
Then you woudl have to select your plotter first ij Plot dialog, then go to Properties and in Device and Document Settinsg add Custom Paper Sizes.
Here is something to get you started: http://low.li/story/2012/12/autocad-tutorial-custom-paper-size-and-grayscale-printing/
BTW, you may first try adding it with your ScanSoft, just in case. Options may be different, though.
Good luck!
Almas Suljevic
Autodesk, Inc.
JDESILVA
Message 10 of 10 (1,133 Views)
04-12-2013 11:36 AM in reply to: AlmasSuljevic
Thank you
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
