C3D 2012 SP3
I have cut my P&P sheets with the production tools. I am using a cut sheet that has alignment and profile data shortcuts in it as a base file. The sheets come out fine, but, I noticed that I cannot segregate the alignment station labeing. In the cut sheet I put the alignments and their stationing on 2 layers. One for objects and one for station labels. Do I need to put each alignment and its labeling on individual layers in the cut sheet, i.e. road1, road2 etc.? Why can't I label the alignment that is displayed on the P&P sheets. I have an Xref of the plan view, whereas, the profile is active in the P&P sheets.
Solved by civman_daar. Go to Solution.
The alignment for the P&P sheets was buried under the Xrefs in the drawing. Changed draw order and labeled the alignment with stationing.
