AutoCAD Civil 3D General
BrianHailey
Message 11 of 15 (316 Views)
Re: pipe networks in section views
11-13-2012 03:58 PM in reply to: lambertb
Unfortunately, there is no way that I'm aware of to accomplish this using pipe networks. As you can see, structures are not one of the things you can project onto a section view.
Project Objects
You could create blocks on your structures that you then project but they won't change as your structures change.
Sorry I don't have a better solution for you.
Distinguished Contributor
Message 12 of 15 (306 Views)
11-14-2012 01:56 AM in reply to: BrianHailey
Perhaps this is a useful feature that Autodesk could include in version 2024, after they've implemented the holographic-cloud-based-silt-monitoring toolset that we are all clamouring for.
;o)
Kevin
Message 13 of 15 (58 Views)
03-11-2014 10:13 AM in reply to: ksorsby
Kevin,
I am trying to do just what you describe above (in Civil 3D 2011). I have an existing sample line group and I want to add a new pipe network to the sources but it is not listed under the availible sources. Did the pipe network have to be in existence when I created the sample lines? Unfortunately I am working somewhat backwards to recreate some things in some drawings for a project I just took over at a new company, so I am not taking the most straight forward approach to some things.
Marie
Message 14 of 15 (50 Views)
03-12-2014 02:10 AM in reply to: IslandGirl83
Hi Marie,
I think I ended up drawing it in by hand - but maybe it's changed since the 2011 version.
I don't have access to the original job anymore but I'll have a look see if it's possible now!
Kevin
Message 15 of 15 (41 Views)
03-12-2014 05:32 AM in reply to: ksorsby
I went and created another sample line group to just see if it would be there. Once I did that the pipe network showed up as a source in the new one, but also in the old sample line group. I am not sure if now if I just missed it before, or if there was some type of reference when I went thought the creation process again. regardless IT is possible to add newly created pipe networks as a source to old sections.
Thanks for your input!
Marie
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
