Civil 3D Forum
pipe network panorama columns
2 REPLIES 2
CADmgrMike
363 Views, 2 Replies
Does anyone know if there is a way to customize the columns for pipes in the pipe network panorama?
I can remove columns from the structures panorama and the settings stay, but if I remove columns from the pipe panorama and reopen the drawing, it reverts back to default settings.
Mike Porter
https://provostandpritchard.com/
2 REPLIES 2
Matt_Haokip
in reply to: CADmgrMike
Hi Mike,
I was unable to replicate your issue, after I have didden some of the columns and saved the drawing, it open the way it was hidden. You may want to check if the issue is specific to the drawing or may be user specific. I also don't think it is possible to customized it, as it is hard coded and you can only hide or show or change the sequence of the columns.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Matt Haokip
CADmgrMike
in reply to: Matt_Haokip
It is working correctly this morning.
I guess it was tired and needed the weekend for rest. 🙂
Thanks.
Mike Porter
Rail Community
