No. That just does color & layer.
I am finding all kinds of odd things with these functions.
I am doing multiple profile views to split onto separate sheets. I use the pipenetworks label all objects in profile, but I can't see anywhere where you select which STYLE to use to label. The label has station offset, but it doesn't seem to pick up the stations of the cross pipes that have 'their own' alignment. It just gives ????
The pipe labels all come in UNDER the pipes, but from what I can see of the style settings, using the ones the setting manager says are in use, both show examples ABOVE the pipe. I can't see the example display in the profile drop down though.
Ann Wingert, P.E.
