I want to create a vent pipe with a cut slope. I reviewed the help menu and selected the extrusion
and it added the axis then nothing after that happen (see attached figure)
Thanks in advance
John
Solved by SethHall. Go to Solution.
Judging from your description, I am not quite sure what is going on. Could you possibly provide a more detailed description along with what is expected? Thanks!
Seth, I reported this same issue in April of last year. Look for CaseNo:08260335. Cut planes haven't worked in Civil 3D since version 2009 which is why I have to keep that version on my system.
Was this ever fixed? I was trying to get an elbow created in part builder and was looking at the cut plane modifier, but it doesn't do what the help file says. There are no grips shown to change anything on it. In fact, changing the viewport to be Wireframe and shaded caused it to crash when I selected the cut plane modifier object.
I just tried it this morning and it's still broken in 2018. I guess not enough people have complained about it to for Autodesk to warrant spending the resources on it to fix it.
I also highly doubt it will ever get fixed as Autodesk is moving towards the Project Kameleon technology that will most likely replace part builder.
I was afraid of that. Autodesk basically doesn't know how to fix anything in C3D because all the original programmers are gone. As for Kameleon, I was a part of it a while ago, but Autodesk basically wouldn't help me with anything regarding it nor anyone else on the forum. Autodesk upgraded the software and the tutorials no longer applied because of so many changes. I checked back every month or so and not a single new post nor comment was even made in there for months. It looked abandoned.
