Hi.
1. If you take a look at the image, you will notice 2 structure labels on the left and 2 on the right. The two on the left is where i would like them to be when I hit add, and on the right is where they actually come in. Is there a way to make the attachment point be the rim and sump vs. the middle of the structure? If not, would be very nice. Also, if the surface changes or structure moves, I would like the attachment point to still be the Rim and Sump.
2. If you look at the pipe labels, you will notice two of the same label. The one with the leader is the problem pipe label. Is there a way to make the leader attach to the outer boundary of the pipe? If not, this would be nicer than item 1. I noticed an option for the anchor point to be the top outer diameter, but this seems to have no affect on the leader.
Thanks in advance.
Brandon
C3D2007, SP1a
