Civil 3D Forum
parcel settings not plotting correctly in 2012
1 REPLY 1
annw2
281 Views, 1 Reply
I either have bad settings or have found a bug in 2012 when plotting parcels.
I have a P-drain Parcel setting for major drainage areas - I set the display to the C-PROP-BNDY layer which seems to be OOB for the entire 'property'.  I create the parcels from poly lines on the P-DRAIN-AREA layer.
The parcels go to the C-PROP layer.  My problem is that I can't seem to get the property lines to plot.  I try to set C-PROP-BNDY to the correct color, yet when I plot, the lines don't show.  C-PROP is on.
Ann Wingert, P.E.
1 REPLY 1
in reply to: annw2
Are there any non-plottable layers in the drawing?
Are the parcel lines turned on in model and plan in the parcel line style?
Does this happen if you pull up the drawing on another computer?
Can you post a sample drawing with just a simple rectangular parcel using the same parcel style?
Rail Community
