Am creating bus bays & laybays using ofset alignments, is there a way to set different transition in/out length in my file i want 20m transition in, 20m widened region length and 15m transition out length. At the moment there is only one option for setting default transition length
Your Name
Your Name
Yep, and you might (will) need a second "widening" to go back to single lane width. So select the first offset with widening, and click the "+" grip to add another widening, then stretch it back towards the CL. This will create a second widening group and you can specify the 15m transition back.
Mike
Hi Mike
not sure I follow you there? One widening off on alignment will give the transistion out and transition in. Why do you need two?
Your Name
Your Name
This is how I do it:
First widening to create first transition.
Second widening to create transition back.
I'm sure there is another way, maybe even more efficient than mine (?) 😉
Mike
Your Name
Your Name
