There are theoretical difficulties with offsetting a clothoid. The curve
created by offsetting a clothoid is NOT another clothoid. (If there is an
algorithm for the curve, I have not been able to find it and lack the
interest to try and derive it myself) Hence when you offset, Civil3D draws
a polyline which matches the offset value somewhere along the clothoid, but
not entirely. For practical purposes this does not matter and I would
expect that computations are done with correct data.
Regards
Laurie Comerford
www.cadapps.com.au
www.civil3dtools.com
wrote in message news:5382113@discussion.autodesk.com...
I have what looks like the same issue here.
Did you successfully resolve this?
The reply I have seen does not, I believe, quite get to the bottom of it -
it is not the spiral that is not offsetting correctly, but the circular arc.
On top of this, the line drawn is not from the ends of the arc, but from
some other 2 points along the arc.
I have exploded the offset polyline and this line is just that, a 'line',
not an 'arc' as it should be.
To add to the confusion, a machine with identical specs does not have this
problem on the same file.
Also, once an alignment is created on this second machine, the problem is
resolved for this alignment on the first.
It seems to be about how these separate machines are creating the
alignments.
Any ideas???
